Api session event editor geotiff add ascii url
API Event to Add new GeoTIFF Item from Web ASCII URL.
| 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | GeoTIFF Name | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Web ASCII URL | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Uploader | |
| 3 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | CRS |
| 200 | Integer[] (GeoTIFF IDs) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/add_ascii_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name 1", "Web ASCII URL 1", "Uploader 1", "CRS 1" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/add_ascii_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "GeoTIFF Name 1", "GeoTIFF Name 2", "GeoTIFF Name 3" ], [ "Web ASCII URL 1", "Web ASCII URL 2", "Web ASCII URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ], [ "CRS 1", "CRS 2", "CRS 3" ] ]'JavaScript Example POST:
body: '[ "GeoTIFF Name 1", "Web ASCII URL 1", "Uploader 1", "CRS 1" ]'
fetch("https://development.tygron.com/api/session/event/editorgeotiff/add_ascii_url/", options)
