Api session event editor building reset function values
Revision as of 06:49, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Reset Function Values
0 REQUIRED (BUILDING Integer ID) Building
1 REQUIRED (FunctionValue or multiple values in array [a, b, c]) Function Value[]
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorbuilding/reset_function_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "LIVABILITY_EFFECT" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorbuilding/reset_function_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "LIVABILITY_EFFECT", "CRITICAL_INFRASTRUCTURE", "NUM_CARS" ] ]'
JavaScript Example POST:
 body: '[ 1, "LIVABILITY_EFFECT" ]'
fetch("https://development.tygron.com/api/session/event/editorbuilding/reset_function_values/", options)
