Api session event editor area generate water areas
API Event to Generate Water Area
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '7'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '47'JavaScript Example POST:
body: '7'
fetch("https://development.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
