Api session event editor area generate sewer areas
Revision as of 06:48, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Generate Sewer Area
0 REQUIRED (Integer number) Integer
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
4 REQUIRED (String) String
200 Integer (Integer)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 86, 10, 30, "Text" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 51, 40, 63, "Text" ]'
JavaScript Example POST:
 body: '[ 1, 86, 10, 30, "Text" ]'
fetch("https://development.tygron.com/api/session/event/editorarea/generate_sewer_areas/", options)
