Api session event editor area set polygons
API Event to Set polygons to existing Area
| 0 | REQUIRED | (AREA Integer ID or multiple values in array [1, 2, 3]) | Area | |
| 1 | REQUIRED | (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) | Area MultiPolygons |
| 200 | Boolean (Content was updated) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/set_polygons/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
'Curl Example multi item POST:
[ [ 1, 2, 3 ], [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
'JavaScript Example POST:
body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]} ]'
fetch("https://development.tygron.com/api/session/event/editorarea/set_polygons/?crs=3857", options)
