Api session event editor area set name
Revision as of 06:48, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set new name of existing Area
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Area
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Area Names
200 Boolean (Content was updated)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Area Name 1" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorarea/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Area Name 1", "Area Name 2", "Area Name 3" ] ]'
JavaScript Example POST:
 body: '[ 1, "Area Name 1" ]'
fetch("https://development.tygron.com/api/session/event/editorarea/set_name/", options)
