Api session event editor address get building
API Event to Get Building
| 0 | REQUIRED | (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) | Address |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoraddress/get_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoraddress/get_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript Example POST:
body: '1'
fetch("https://development.tygron.com/api/session/event/editoraddress/get_building/", options)
