Api session event editor start map creation
Revision as of 06:47, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the Project's georeference center point to the provided coordinates and begin the process of automatically load in available data.
0 REQUIRED (Floating point number) Center point (Longitude or X coordinate)
1 REQUIRED (Floating point number) Center point (Latitude or Y coordinate)
2 OPTIONAL (MultiPolygon with crs: EPSG:3857) Optional: Limit data loading to this Polygon
3 OPTIONAL (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) Optional: Area of Interest Polygons
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 82, 73, "", "" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editor/start_map_creation/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 63, 53, "", "" ]'
JavaScript Example POST:
 body: '[ 82, 73, "", "" ]'
fetch("https://development.tygron.com/api/session/event/editor/start_map_creation/?crs=3857", options)
