Api session event editor weather set duration
API Event to Set how long the specified Weather's visualization lasts when it is Triggered.
| 0 | REQUIRED | (WEATHER Integer ID) | Weather ID | |
| 1 | REQUIRED | (Floating point number) | Duration of visualization in seconds |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 4 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_duration/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 41 ]'JavaScript Example POST:
body: '[ 1, 4 ]'
fetch("https://development.tygron.com/api/session/event/editorweather/set_duration/", options)
