Api session event editor weather set name
API Event to Set the name for a specified Weather.
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Name for the Weather
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name for the weather 1" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name for the weather 1", "Name for the weather 2", "Name for the weather 3" ] ]'
JavaScript Example POST:
 body: '[ 1, "Name for the weather 1" ]'
fetch("https://development.tygron.com/api/session/event/editorweather/set_name/", options)
