Api session event editor unitdataoverride add
API Event to Add new Unit Data Override
0 REQUIRED (UNIT_DATA Integer ID) Unit Data
200 Integer (Integer)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorunitdataoverride/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://development.tygron.com/api/session/event/editorunitdataoverride/add/", options)
