Api session event editor stakeholder set start budget
API Event to Set Start Budget
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 99 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorstakeholder/set_start_budget/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 47 ]'
JavaScript Example POST:
 body: '[ 1, 99 ]'
fetch("https://development.tygron.com/api/session/event/editorstakeholder/set_start_budget/", options)
