Api session event editor sound set volume
API Event to Set Volume
0 REQUIRED (SOUND Integer ID) Sound
1 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 47 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 15 ]'
JavaScript Example POST:
 body: '[ 1, 47 ]'
fetch("https://development.tygron.com/api/session/event/editorsound/set_volume/", options)
