Api session event editor setting set timestamp format
API Event to Set Timetamp Format
0 REQUIRED (String) String
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/set_timestamp_format/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'
JavaScript Example POST:
 body: '"Text"'
fetch("https://development.tygron.com/api/session/event/editorsetting/set_timestamp_format/", options)
