Api session event editor setting set setting
API Event to Set Project Setting
| 0 | REQUIRED | (Enumeration) | Setting Type | ACTIVE_SCENARIO, AREA_GROUPS, AUTO_CALCULATION, BASE_PANELS, CURRENCY, DECIMALS, DEFAULT_GEOPLUGINS, DEFAULT_GROUND_LOWER_PRICE_M3, DEFAULT_GROUND_RAISE_PRICE_M3, DEFAULT_GROUNDPRICE_M2, DETAILED, EXPORT_CRS, GRID_CELL_SIZE_M, IMPORT_CRS, IMPORT_CRS_FORCE_XY, ITERATIONS, KEEP_ALIVE, LIMIT_MAP, MAP_SIZE_M, MAX_TOTAL_GRIDCELLS, MEASUREMENT_SYSTEM_TYPE, MIN_CELL_M, MODEL_STYLE, PROJECT_NAME, RASTERIZATION, RECALCULATION_REQUIRED, RECENT_CRSS, REGION, RESERVED_LAND, SATELLITE_BRIGHTNESS, SATELLITE_COLOR, SATELLITE_FILE_NAME, SCHEDULED_UPDATE, SCHEDULED_UPDATE_MAIL, SCHEDULED_UPDATE_SMS, SECTOR_SIZE_M, SHOW_ACTION_LOG, SHOW_BUILDING_AND_MEASURE_POPUP, SHOW_WATER_POPUP, SKY_TYPE, SOLAR_PANEL_POSITION, STATE, SUN_DATES, SUPER_USER_MESSAGE, SUPPORT, SURROUNDING_MAP_EXTEND_M, TIME_ZONE, TIMESTAMP_FORMAT, TRAFFIC_VISUAL_MULTIPLIER, WATER_HEIGHT, WATER_TYPE, WEB_ALLOW_LOGIC_EVENT, WEB_ALLOW_PARTICIPANT_EVENT, WEB_ALLOW_QUERIES, WEB_BASE_MAP, WEB_DEFAULT_APP, WEB_FRONT_PANEL, WEB_MAP_CUSTOM_PANEL, WEB_MODEL_SHADOW, WEB_MODEL_SPACING, WEB_MODEL_STYLE, WEB_MODEL_TEXTURE, WIND_DIRECTION, WIND_SPEED_M_PER_S, WIZARD_TIME_MINUTES or WORLD_REFERENCE_POINT |
| 1 | REQUIRED | (String) | Value as String (can be a integer, boolean, text, etc.) |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/set_setting/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "AREA_GROUPS", "Value as String" ]'JavaScript Example POST:
body: '[ "AREA_GROUPS", "Value as String" ]'
fetch("https://development.tygron.com/api/session/event/editorsetting/set_setting/", options)
