Api session event editor setting set permission popup active
API Event to Set Permission Popup Active
| 0 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/set_permission_popup_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/set_permission_popup_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'JavaScript Example POST:
body: 'false'
fetch("https://development.tygron.com/api/session/event/editorsetting/set_permission_popup_active/", options)
