Api session event editor setting get sun motion
API Event to Get Sun Motion value for local Time in this Project (The Netherlands only)
| 0 | REQUIRED | (Integer number) | Year | |
| 1 | REQUIRED | (Integer number) | Month | |
| 2 | REQUIRED | (Integer number) | Day | |
| 3 | REQUIRED | (Integer number) | Hour | |
| 4 | REQUIRED | (Integer number) | Minute | |
| 5 | REQUIRED | (Integer number) | Second |
| 200 | Double (Sun Motion value) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/get_sun_motion/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 2013, 8, 2, 12, 0, 0 ]'JavaScript Example POST:
body: '[ 2013, 8, 2, 12, 0, 0 ]'
fetch("https://development.tygron.com/api/session/event/editorsetting/get_sun_motion/", options)
