Api session event editor setting get sun azimuth
API Event to Get Sun Azimuth value for local Time in this Project
0 REQUIRED (Integer number) Year
1 REQUIRED (Integer number) Month
2 REQUIRED (Integer number) Day
3 REQUIRED (Integer number) Hour
4 REQUIRED (Integer number) Minute
5 REQUIRED (Integer number) Second
200 Double (Sun Azimuth value)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/get_sun_azimuth/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 2013, 8, 2, 12, 0, 0 ]'
JavaScript Example POST:
 body: '[ 2013, 8, 2, 12, 0, 0 ]'
fetch("https://development.tygron.com/api/session/event/editorsetting/get_sun_azimuth/", options)
