Api session event editor scenario add measure
API Event to Add a Measure that is Triggered on Scenario activation.
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario ID | |
| 1 | REQUIRED | (MEASURE Integer ID) | Measure ID |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorscenario/add_measure/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editorscenario/add_measure/", options)
