Api session event editor parametric apply
API Event to Apply
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID) | Parametric Design | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 2 | REQUIRED | (FunctionType or multiple values in array [a, b, c]) | FunctionType[] | |
| 3 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] | |
| 4 | REQUIRED | (MultiPolygon or multiple values in array [a, b, c]) | MultiPolygon[][] |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorparametric/apply/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, "ROAD", 1, [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658636.762, 6799441.896 ], [ 658636.762, 6799451.896 ], [ 658646.762, 6799451.896 ], [ 658646.762, 6799441.896 ], [ 658636.762, 6799441.896 ] ] ] ]
'Curl Example multi item POST:
[ 1, 1, [ "ROAD", "WATER", "PARKING" ], [ 1, 2, 3 ], [ [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658646.762, 6799441.896 ], [ 658646.762, 6799451.896 ], [ 658656.762, 6799451.896 ], [ 658656.762, 6799441.896 ], [ 658646.762, 6799441.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799441.896 ], [ 658656.762, 6799451.896 ], [ 658666.762, 6799451.896 ], [ 658666.762, 6799441.896 ], [ 658656.762, 6799441.896 ] ] ] ]
'JavaScript Example POST:
body: '[ 1, 1, "ROAD", 1, [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799441.896 ], [ 658636.762, 6799451.896 ], [ 658646.762, 6799451.896 ], [ 658646.762, 6799441.896 ], [ 658636.762, 6799441.896 ] ] ] ]} ] ]'
fetch("https://development.tygron.com/api/session/event/editorparametric/apply/", options)
