Api session event editor panel set for stakeholder
API Event to Set For Stakeholder
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/set_for_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editorpanel/set_for_stakeholder/", options)
