Api session event editor panel add overlay template
API Event to Add Overlay Template
| 0 | REQUIRED | (Enumeration) | PanelTemplate | DANGEROUS_OBJECTS, NETWORK_INTERACTION, TRAFFIC_NOISE, WATER_AREAS or WEIRS |
| 1 | REQUIRED | (OVERLAY Integer ID) | Overlay |
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/add_overlay_template/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TRAFFIC_NOISE", 1 ]'JavaScript Example POST:
body: '[ "TRAFFIC_NOISE", 1 ]'
fetch("https://development.tygron.com/api/session/event/editorpanel/add_overlay_template/", options)
