Api session event editor panel add answer
API Event to Add Answer (Panel)
| 0 | REQUIRED | (PANEL Integer ID) | Panel |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/add_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript Example POST:
body: '1'
fetch("https://development.tygron.com/api/session/event/editorpanel/add_answer/", options)
