Api session event editor overlay set key value
API Event to Change a key for a specified Overlay. The Overlay must be an Overlay which makes use of keys to read attributes of geographical items, as input for its calculation.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a grid Overlay)
1 REQUIRED (String) Key name
2 REQUIRED (String) Attribute to look for
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_key_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Key name", "Attribute to look for" ]'
JavaScript Example POST:
 body: '[ 1, "Key name", "Attribute to look for" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_key_value/", options)
