Api session event editor overlay set geotiff
API Event to Change the GeoTIFF displayed by a specified GeoTIFF Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a GeoTIFF Overlay)
1 REQUIRED (GEO_TIFF Integer ID or multiple values in array [1, 2, 3]) Unique GeoTIFF IDs
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_geotiff/", options)
