Api session event editor overlay set avg distance
API Event to Set the averaging distance for a specified AVG Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to an AVG Overlay)
1 REQUIRED (Floating point number) Averaging distance
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 32 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 88 ]'
JavaScript Example POST:
 body: '[ 1, 32 ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_avg_distance/", options)
