Api session event editor netnode set location
API Event to Set Location
0 REQUIRED (Enumeration) Network type ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (NET_NODE Integer ID) Net Node ID
2 REQUIRED (Point 3D with crs: EPSG:3857) Location Point
3 OPTIONAL (Floating point number) Node merge distance (optional, default: 1.0m)
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetnode/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", 1, {
 "type" : "Point",
 "coordinates" : [ 658758.9780925934, 6799348.022579272, -0.53 ]
}, 1.0 ]
Curl Example multi item POST:
 "type" : "Point",
 "coordinates" : [ 658790.9394667842, 6799449.764168823, -1.79 ]
}, 1.0 ]
JavaScript Example POST:
 body: '[ "ELECTRICITY", 1, { "type" : "Point", "coordinates" : [ 658758.9780925934, 6799348.022579272, -0.53 ]}, 1.0 ]'
fetch("https://development.tygron.com/api/session/event/editornetnode/set_location/?crs=3857", options)
