Api session event editor netload remove node
API Event to Remove Node
0 REQUIRED (NET_LOAD Integer ID) Net Load
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetload/remove_node/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://development.tygron.com/api/session/event/editornetload/remove_node/", options)
