Api session event editor netload add and set node
API Event to Add And Set Node
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Load | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658743.2467103883, 6799426.5455873255 ]
'Curl Example multi item POST:
[ 1, {
"type" : "Point",
"coordinates" : [ 658766.4734806665, 6799368.036551539 ]
'JavaScript Example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658743.2467103883, 6799426.5455873255 ]} ]'
fetch("https://development.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
