Api session event editor netline remove attribute
API Event to Remove the specified attributes for each specified Net Line
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Net Line IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attributes
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetline/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute 1" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editornetline/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute 1", "Attribute 2", "Attribute 3" ] ]'
JavaScript Example POST:
 body: '[ 1, "Attribute 1" ]'
fetch("https://development.tygron.com/api/session/event/editornetline/remove_attribute/", options)
