Api session event editor measure set terrain height relative
API Event to Set whether the inner height of Terrain Spatial of a Measure is considered relative.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure IDs | |
| 1 | REQUIRED | (Integer number) | Terrain Spatial ID | |
| 2 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_terrain_height_relative/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_terrain_height_relative/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false ]'JavaScript Example POST:
body: '[ 1, 1, true ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_terrain_height_relative/", options)
