Api session event editor measure set terrain height
API Event to Set the inner height of Terrain Spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number) Terrain Spatial ID
2 REQUIRED (Floating point number) Height value
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 53 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 32 ]'
JavaScript Example POST:
 body: '[ 1, 1, 53 ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_terrain_height/", options)
