Api session event editor levee set is relative increase
API Event to Set Is Relative Increase
| 0 | REQUIRED | (LEVEE Integer ID) | Levee | |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorlevee/set_is_relative_increase/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorlevee/set_is_relative_increase/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'JavaScript Example POST:
body: '[ 1, true ]'
fetch("https://development.tygron.com/api/session/event/editorlevee/set_is_relative_increase/", options)
