Api session event editor indicator set target
API Event to Set a target value of an Indicator for a Sceanrio. A target index value is required.
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario ID | |
| 1 | REQUIRED | (INDICATOR Integer ID) | Indicator ID | |
| 2 | REQUIRED | (Integer number) | Target index | |
| 3 | REQUIRED | (Floating point number) | Target value |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorindicator/set_target/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 47 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorindicator/set_target/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 71 ]'JavaScript Example POST:
body: '[ 1, 1, 1, 47 ]'
fetch("https://development.tygron.com/api/session/event/editorindicator/set_target/", options)
