Api session event editor global set visualisation name
API Event to Set Visualisation Name
0 REQUIRED (GLOBAL Integer ID) Global
1 REQUIRED (String) String
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorglobal/set_visualisation_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'
JavaScript Example POST:
 body: '[ 1, "Text" ]'
fetch("https://development.tygron.com/api/session/event/editorglobal/set_visualisation_name/", options)
