Api session event editor geotiff add ascii url
API Event to Add new GeoTIFF Item from Web ASCII URL.
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) GeoTIFF Name
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Web ASCII URL
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Uploader
3 REQUIRED (String or multiple values in array ["a", "b", "c"]) CRS
200 Integer[] (GeoTIFF IDs)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/add_ascii_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name 1", "Web ASCII URL 1", "Uploader 1", "CRS 1" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/add_ascii_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "GeoTIFF Name 1", "GeoTIFF Name 2", "GeoTIFF Name 3" ], [ "Web ASCII URL 1", "Web ASCII URL 2", "Web ASCII URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ], [ "CRS 1", "CRS 2", "CRS 3" ] ]'
JavaScript Example POST:
 body: '[ "GeoTIFF Name 1", "Web ASCII URL 1", "Uploader 1", "CRS 1" ]'
fetch("https://development.tygron.com/api/session/event/editorgeotiff/add_ascii_url/", options)
