Api session event editor geotiff add ascii
API Event to Add new GeoTIFF Item with provided ASCII file. For files larger than 2GB, use the Stream API or Web URL.
0 REQUIRED (String) GeoTIFF Name
1 REQUIRED (byte or multiple values in array [a, b, c]) ASCII File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 REQUIRED (String) CRS
200 Integer (GeoTIFF ID)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/add_ascii/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", 1, "Uploader", "CRS" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/add_ascii/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "CRS" ]'
JavaScript Example POST:
 body: '[ "GeoTIFF Name", 1, "Uploader", "CRS" ]'
fetch("https://development.tygron.com/api/session/event/editorgeotiff/add_ascii/", options)
