Api session event editor excelsheet set excel sheet
API Event to Set Excel Sheet
0 REQUIRED (EXCEL_SHEET Integer ID) Excel Sheet
1 REQUIRED (byte or multiple values in array [a, b, c]) byte[]
2 REQUIRED (String) String
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorexcelsheet/set_excel_sheet/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorexcelsheet/set_excel_sheet/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], "Text" ]'
JavaScript Example POST:
 body: '[ 1, 1, "Text" ]'
fetch("https://development.tygron.com/api/session/event/editorexcelsheet/set_excel_sheet/", options)
