Api session event editor area generate water areas
API Event to Generate Water Area
0 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '26'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_water_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '33'
JavaScript Example POST:
 body: '26'
fetch("https://development.tygron.com/api/session/event/editorarea/generate_water_areas/", options)
