Api session event editor area generate sewer areas
API Event to Generate Sewer Area
0 REQUIRED (Integer number) Integer
1 REQUIRED (Floating point number) Double
2 REQUIRED (Floating point number) Double
3 REQUIRED (Floating point number) Double
4 REQUIRED (String) String
200 Integer (Integer)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 5, 97, 19, "Text" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 81, 87, 76, "Text" ]'
JavaScript Example POST:
 body: '[ 1, 5, 97, 19, "Text" ]'
fetch("https://development.tygron.com/api/session/event/editorarea/generate_sewer_areas/", options)
