Api session event editor weather remove attribute
Revision as of 12:15, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove the specified attributes of the specified Weather. The attributes, including attributes which are added to a Weather by default, are removed entirely.
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attributes to remove
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorweather/remove_attribute/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Attributes to remove 1", "Attributes to remove 2", "Attributes to remove 3" ] ]
