Api session event editor weather duplicate
Revision as of 12:15, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Create a copy of each specified Weather. The copies will have the same Setting and attributes, but can be edited independently of the originals.
0 REQUIRED (WEATHER Integer ID or multiple values in array [1, 2, 3]) Weather IDs
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorweather/duplicate/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
