Api session event editor trigger add
Revision as of 12:15, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new Trigger
0 OPTIONAL (Timing or multiple values in array [a, b, c]) Timing[]
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editortrigger/add/?f=JSON&token=API_TOKEN
with content:
