Api session event editor stakeholder select stakeholder
API Event to Select Stakeholder with preferred ID, when not available fallback to next best.
| 0 | REQUIRED | (Integer number) | Preferred Stakeholder ID or empty | |
| 1 | REQUIRED | (String) | Client Token (from Join Session event) |
| 200 | Integer (Selected Stakeholder ID) |
Example POST: https://engine.tygron.com/api/session/event/editorstakeholder/select_stakeholder/?f=JSON&token=API_TOKEN
with content:
[ 16, "Client Token" ]
