Api session event editor source add catalog
Revision as of 12:14, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add Catalog
0 REQUIRED (Enumeration) GeoCatalog CSW or ESRI
1 REQUIRED (String) String
2 REQUIRED (String) String
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorsource/add_catalog/?f=JSON&token=API_TOKEN
with content:
[ "ESRI", "Text", "Text" ]
