Api session event editor sound set filename
Revision as of 12:14, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Filename
0 REQUIRED (SOUND Integer ID) Sound
1 REQUIRED (String) String
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorsound/set_filename/?f=JSON&token=API_TOKEN
with content:
[ 66, "Text" ]
