Api session event editor sound remove
Revision as of 12:14, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove existing Sound
0 REQUIRED (SOUND Integer ID or multiple values in array [1, 2, 3]) Sound
Example POST: https://engine.tygron.com/api/session/event/editorsound/remove/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
