Api session event editor setting get sun altitude
Revision as of 12:13, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Get Sun Altitude value for local Time in this Project
0 REQUIRED (Integer number) Year
1 REQUIRED (Integer number) Month
2 REQUIRED (Integer number) Day
3 REQUIRED (Integer number) Hour
4 REQUIRED (Integer number) Minute
5 REQUIRED (Integer number) Second
200 Double (Sun Altitude value)
Example POST: https://engine.tygron.com/api/session/event/editorsetting/get_sun_altitude/?f=JSON&token=API_TOKEN
with content:
[ 2013, 8, 2, 12, 0, 0 ]
