Api session event editor scenario set restart testrun
Revision as of 12:13, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to When true test run is restarted on Scenario activation. This option will be deprecated in the future and replaced by multiple maps.
0 REQUIRED (SCENARIO Integer ID or multiple values in array [1, 2, 3]) Scenario ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Restart required
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
