Api session event editor scenario append attribute
Revision as of 12:13, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Appended to existing Scenario attribute value
0 REQUIRED (SCENARIO Integer ID or multiple values in array [1, 2, 3]) Scenario
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values appended to existing values
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorscenario/append_attribute/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]
